VictorK Posted May 10, 2010 Report Posted May 10, 2010 (edited) i didn t say i wanted to beat them, i have built a banshee in 2 months last year that smoked them . i just wanna harang them on a 1 lunger. sorry I didnt get that one borich's bike should be pretty fast already I bet. does it have a LRD powervalved top end? Edited May 10, 2010 by VictorK Quote
Koolguyson Posted May 10, 2010 Report Posted May 10, 2010 Depends if your friends have a true 75 horse. If so, it'll take a 370 if you're on a budget (used), or a puma if you can afford it. The 370 will be a little behind them, and the puma will most likely beat them if set up right. Pumas are making an honest 100hp now on alk...pretty amazing for a 400cc motor. The 370s are around 80ish on alk. I know you aren't drag racing, or running methanol. But it gives you an idea of the hp discrepancy. Quote
NYUK Posted May 10, 2010 Report Posted May 10, 2010 Depends if your friends have a true 75 horse. If so, it'll take a 370 if you're on a budget (used), or a puma if you can afford it. The 370 will be a little behind them, and the puma will most likely beat them if set up right. Pumas are making an honest 100hp now on alk...pretty amazing for a 400cc motor. The 370s are around 80ish on alk. I know you aren't drag racing, or running methanol. But it gives you an idea of the hp discrepancy. yeah they are, i set them up. o h well i will just restore it as is over winter. i ain t getting into case mods and shit. just gonna keep it the way it is. maybe trade it. Quote
