Fastassbanshee96 Posted May 8, 2010 Report Posted May 8, 2010 I have a set of haulers and one of the paddles started to lift from the tire. It's not too bad but am wondering if there is anything out there to glue it back in place or something. I know it probably won't hold for long but would just like to get atleast another season out of them. Quote
Larry's Shee Posted May 8, 2010 Report Posted May 8, 2010 Don't know if there are any tire recappers still in this area, might check with one of them. Used to be one in Rochester. Quote
Fastassbanshee96 Posted May 8, 2010 Author Report Posted May 8, 2010 Don't know if there are any tire recappers still in this area, might check with one of them. Used to be one in Rochester. So you don't know of any glue or anything I can use as a quick fix on it. Quote
AKheathen Posted May 9, 2010 Report Posted May 9, 2010 i really don't think your std. vulcanizing compound will hold a paddle down, and i know cyanoacrylate (super glue/plane-hobby glue) will hold a butt joint on an o-ring, but tire cappers use an adhesive to glue the new tread on old tires, and that will hold permenantly. you may get away with window weld- windsheild eurothane, which is some pretty strong stuff, but anything else you use as a temp fix might keep it from being repaired the right way later. Quote
