shee23 Posted May 7, 2010 Report Share Posted May 7, 2010 Im replacing second gear in my transmission but since I already have the cases apart I want to replace everything I need to. So what is the best way to tell if my crank bearings are bad, my shift forks, and all my other gears. thanks fellas Quote Link to comment Share on other sites More sharing options...
shee23 Posted May 7, 2010 Author Report Share Posted May 7, 2010 any ideas would help Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 8, 2010 Report Share Posted May 8, 2010 Check that bearings turn smoothly with no excessive noise. Look closely for pits, galling, discoloration from heat. Same viual inspection for trans, look at forks for bending, check shafts forks ride on for straightness. Look at gears for chips , etc. Look at dogs for burrs or excess wear. Hope this helps. Your results may vary. Quote Link to comment Share on other sites More sharing options...
ibmenace Posted May 8, 2010 Report Share Posted May 8, 2010 also check your crank arms for any slop or play while the bottom of the arms are on the down stroke. if they are not tight and solid you may want to consider replacing that while you are in there. i had this happen to me while a buddy and i were were looking into a tranny issue also. Quote Link to comment Share on other sites More sharing options...
shee23 Posted May 8, 2010 Author Report Share Posted May 8, 2010 cool that helps allot thanks Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 8, 2010 Report Share Posted May 8, 2010 Put it in v-blocks and check the bearing run out with a guage good to the .001 Quote Link to comment Share on other sites More sharing options...
