Got a crank that was supposed to be Vito's 4mm 110mm rod. It has 29L on the rods and what I'm getting from google is that is the numbers on the stock crank, or at least the part number that is showing up for everything banshee, stock crank related. It's not out of the cases yet so I can't measure anything and it didn't have cylinders/pistons so I can't check that either. Anyone know if this could in fact still be a Vito's 4mm crank, just going off of 29L.
you can probably call vitos and ask
