when installing a case saver do i need to remove the white plastic part thats held on with 3 med. screws and 1 small one or just place the saver over it?
any help will be great thanx
it should come with 3 longer screws that replace the 3 that hold that white cover on. dont take it off, just place the case saver over it and use the 3 longer screws.
x2 my tusk case saver came with 3 longer allen head screws but they were too long so i had to use washers to make it work but now everything is peachy.
x2, I had to do the same thing.
There is a least 1 brand that you do need to remove the nuetral switch to install the casesaver. You can tell because the inside of the case saver looks just like the inside of the nuetral switch. I don't remember what brand it is though.
