toytech Posted May 3, 2010 Report Posted May 3, 2010 what is the min clearance between the top of the piston and the dome that is safe on a 4mill crank stock cylinder motor ? Quote
SAVAGE420 Posted May 3, 2010 Report Posted May 3, 2010 If your looking for squish clearance numbers, then somewhere between .042-052 ish is fine. Quote
toytech Posted May 3, 2010 Author Report Posted May 3, 2010 If your looking for squish clearance numbers, then somewhere between .042-052 ish is fine. thanks Quote
strokersquid Posted May 4, 2010 Report Posted May 4, 2010 would that work with pump gas ? we only have 91 here in Ca Quote
toytech Posted May 4, 2010 Author Report Posted May 4, 2010 (edited) would that work with pump gas ? we only have 91 here in Ca if compression is over 150 wich it should be, no anything over that needs race fuel Edited May 4, 2010 by toytech Quote
