The shee runs great and im confused...........GPS Last weekend, 92.1 mph and pulled sand tires all weekend, pulled plugs two totally different readings, the flat surface closest to piston one chocolate color and one nothing(silver)....I have polished ports, shearer pipes, stock carbs with 27.5 pilots and 300 mains, + 4 timing, .20 over, carbs are totally synched with carb sync tool...ANY IDEAS WHY? :confused:
leakdown test, maybe u have air leaks?
yeah could be, i think i may try a little starter fluid (ether) and see if i can get the motor to rev up and find leak, i think it'll work, emphasis on a little ether!!!!!!
which plug came from which side?
plug on stator side is lean, plug on clutch side is perfect
