tf06shee
Everything posted by tf06shee
  1. plug on stator side is lean, plug on clutch side is perfect
  2. pump gas 91 octane
  3. yeah could be, i think i may try a little starter fluid (ether) and see if i can get the motor to rev up and find leak, i think it'll work, emphasis on a little ether!!!!!!
  4. what elevation r u at?........look at jetting forum and find similar shee and elevation---------http://bansheehq.com/forums/index.php?showtopic=99361n
  5. The shee runs great and im confused...........GPS Last weekend, 92.1 mph and pulled sand tires all weekend, pulled plugs two totally different readings, the flat surface closest to piston one chocolate color and one nothing(silver)....I have polished ports, shearer pipes, stock carbs with 27.5 pilots and 300 mains, + 4 timing, .20 over, carbs are totally synched with carb sync tool...ANY IDEAS WHY?
  6. 1) What type of aftermarket exhaust do you have? --------shearer small bore in frames 2) What type of airfilter do you have?----------- K/N pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all--------no airbox 4) What is your elevation? --------------sealevel 5) What size pilot jets are you using? ------------27.5 6) What size main jets are you using? -----------300 7) What temperature is your Banshee jetted for?-------- 80 + 8) Do you have a port job? ----------cleanup 9) What kind of carbs? --------mikuni 10) What size carbs? ---------- stock 26mm 11) Air screws?--------- 1.5 out 12) Needle and position?------- stock / middle 13) Timing? -------+4
