GleasmJA Posted April 29, 2010 Report Posted April 29, 2010 I've lost spark and can't find the culprit that is causing this. I've swapped the CDI with a known good. Tested my coil on the same shee that i got the CDI -tested good and just installed a new stator and pick-up. STILL NOTHING. The weird thing is..... if it sits for a while and i look at the plugs when i first kick it over, i see about one spark and then it goes away. Anyone see something like this before????? Quote
SAVAGE420 Posted April 29, 2010 Report Posted April 29, 2010 Try new caps and wires? Broken wire some place? Tested the kill and key switches if you have them still? Happen just outa the blue one day? Quote
GleasmJA Posted April 29, 2010 Author Report Posted April 29, 2010 (edited) Try new caps and wires? Broken wire some place? Tested the kill and key switches if you have them still? Happen just outa the blue one day? Test the whole coil on another shee.... worked fine Tested kill switch and key... both work fine. Just happened out of the blue while riding. I don't have a ground anywhere that it shouldn't be that i have tested yet.... Dreading having to pull the wiring harness and test it all out. Edited April 29, 2010 by GleasmJA Quote
bansheesandrider Posted April 29, 2010 Report Posted April 29, 2010 Test the whole coil on another shee.... worked fine Tested kill switch and key... both work fine. Just happened out of the blue while riding. I don't have a ground anywhere that it shouldn't be that i have tested yet.... Dreading having to pull the wiring harness and test it all out. Did you check the pickup coil gap? Quote
GleasmJA Posted April 29, 2010 Author Report Posted April 29, 2010 pick up gap checked and and was .019...... Quote
GleasmJA Posted April 29, 2010 Author Report Posted April 29, 2010 Magnets till attracted the wood-ruff key when i pulled it off. So i don't beleive so???? Quote
