michaud321 Posted April 22, 2010 Report Posted April 22, 2010 Hey. what is the gas pressure of the stock rear shock? thanks Quote
SAVAGE420 Posted April 22, 2010 Report Posted April 22, 2010 200PSI of dry nitrogen give or take. There's also a 0 by-pass valve that you need to use to get the exact psi due to the fact that the reservoir is so small. Whatever you do, just dont use regular air in the shocks. Quote
Scotty Posted April 30, 2010 Report Posted April 30, 2010 200PSI of dry nitrogen give or take. There's also a 0 by-pass valve that you need to use to get the exact psi due to the fact that the reservoir is so small. Whatever you do, just dont use regular air in the shocks. I was just wondering the same thing. You have an estimate for what it would cost to fill a rear reservoir? Quote
SAVAGE420 Posted May 1, 2010 Report Posted May 1, 2010 I was just wondering the same thing. You have an estimate for what it would cost to fill a rear reservoir? 10-15 bux tops, sometimes guys will do it for free. Takes about 5 seconds to do. Quote
Scotty Posted May 1, 2010 Report Posted May 1, 2010 10-15 bux tops, sometimes guys will do it for free. Takes about 5 seconds to do. Right on thanks. Devol Racing is right down the road from me, I grew up with one of them maybe it will be free. Except they are kind of dicks... Quote
