Thanks for going into details, i heard some ppl say that long travel on a banshee is a waste of time because of the geometry of the frame(longer travel causes bump steer) but ive seen other ppl say that a longer shock even tho its not a true long travel will still be better
I understand alot more now, so like you said if i go with the longer float X evol i would adjust the shocks to limit travel a bit so im not in the bad bumpsteer zone,by doing that i should still have an advantage over running the float X with stock shock mount a arms,bumpsteer with longer shocks was what i was worried about but with the float x evol,if u can fix it,or make it better that seems like a better choice
If i would go with the float X evol id get Laeger's long travel +3 a arms.
since the float X are stock banshee length id probably go with the ASR MX pro +3 arms.
I always thought that the float X evol would be better cause there 19.5" long and the Float X are stock length which is roughly 5" difference but from reading i was starting to think twice, after reading what you said its more clear now.
Even for the extra money im leaning towards the float X evol with the LT a arms,mostly because the Float X is a stock length shock and that would limit you
hopefully this makes sense,sorry if i repeated anything twice
its kinda funny that you replyed cause after seeing your posts about redoing your front end,thats what really got me interested in the Fox Floats
