midlifecrisis Posted April 22, 2010 Report Posted April 22, 2010 OK, So I finally got the bike back together after having to cleanout the bottom end. I have installed a new vitos crank, pistons/rings, ported cylinders, vitos cool head and a few small other things. I have tried to start it and the carbs dont seem to be getting fuel? I have checked the obvious stuff like fuel petcock, fuel level, gas cap breather etc.... I have had the carbs out and checked the floats, fuel lines etc.... I have removed the overflow screws at the bottom of each carb bowl, and there is fuel there. Any ideas? Quote
baker Posted April 22, 2010 Report Posted April 22, 2010 do ya got the bowls on the correct sides? choke crossover tube in place? choke jet in place? did ya clean the jets out make sure they aint plugged? Quote
midlifecrisis Posted April 22, 2010 Author Report Posted April 22, 2010 do ya got the bowls on the correct sides? choke crossover tube in place? choke jet in place? did ya clean the jets out make sure they aint plugged? The bowls were only taken off one of a time, so they were put back on the way that I got them. Whats the difference? The crossover tube is in place. The choke jet is a good question, Ill look in the manual for that one. The jets were cleaned thoroughly. Quote
baker Posted April 22, 2010 Report Posted April 22, 2010 The bowls were only taken off one of a time, so they were put back on the way that I got them. Whats the difference? The crossover tube is in place. The choke jet is a good question, Ill look in the manual for that one. The jets were cleaned thoroughly. the difference is there is a left bowl and a right bowl. the left bowl has the choke pickup tube with a jet in it. Quote
