pweezy42 Posted April 20, 2010 Report Posted April 20, 2010 looking to see what everyone uses i need a new one mine is hard to pull. i am getting a new cable and springs as well Quote
locogato11283 Posted April 20, 2010 Report Posted April 20, 2010 i run the msr easy pull. got it from rmatv. pull the clutch in with one for two fingers. 6 HD springs and a lockup. Quote
SAVAGE420 Posted April 20, 2010 Report Posted April 20, 2010 ASV shorty brake and clutch levers, F.A.S.T clutch, WELL lubed cable, not pulling in the clutch like a pussy girl = priceless Quote
pweezy42 Posted April 20, 2010 Author Report Posted April 20, 2010 what is the cable lube called and where can i get it? Quote
jasons Posted April 20, 2010 Report Posted April 20, 2010 any motorcycle shop will have cable lube. make sure you get the cable lube tool to or you will make a huge mess while lubing the cables. lube the throttle as well.and make sure it comes out the other end. Quote
SAVAGE420 Posted April 20, 2010 Report Posted April 20, 2010 what is the cable lube called and where can i get it? I got mine from Jeff. Comes with the tool and lube that will last almost forever http://www.farmandsandtoys.com/partdetail.asp?partid=323 Quote
Flash and Flare Posted April 20, 2010 Report Posted April 20, 2010 Magura hydro shorty, with 3 HD springs and 3 medium springs. No slippage due to running a Hinson 8 plate set up. Can pull with 2 or 3 fingers Quote
