I have 30 o.k.o's. Im currently running a 140 main which I think I may need a 142 or 5 due to lose of power way up top of like 5th and 6th. Tried a 148 and it was rich and 135 is lean. I also have 55 piolets and takes couple kicks to start so I was thinking I was fat on the piolet maybe a 52 would be good. But this brings me to my ? How does it feel when a bike revs out to a pipe. The pc,s are low to mid so would they rev out making it feel like a jetting issue any input will be great.
This is more than likely a jetting or electrical problem. Just because a low-mid pipe focuses the power around that rpm range, doesn't mean it wont pull a high gear. My bike revs out into 6th gear no problem. You need to check the jetting thread to see what other people are running for jetting in those carbs, or call cascade innovations and ask them for specs.
I think u are very rich on pilots. I just got a 4 mill mx port from hjr and i had to drop down to a 45 pilot
I dropped the bike down to a 48 piolet and it was real lean idole hung up for a good minute. I'm at a 55 now gonna drop down to a 52 see what happens. What carbs are you running
Gonna call cascade and see what they say. But you think the fuel delevery is slacking in these carbs.
Pilot jets have nothing to do with the top end. Thats main jet. Midrange is needle. Idle and up to 1/8 or so throttle is the pilot.
I dont think the fuel delivery is slacking. I think more than likely they are jetted improperly.
28 pwk open airbox k n sea level
