jonnybanshee Posted April 11, 2010 Report Share Posted April 11, 2010 ok so i have a problem with my 88 shee.... i rode yesterday with no problems and then today i got to fire it up and it fired up for a second and died .... so i check for fuel and spark and found that i had no spark.... i check both the stator and pickup coil and everything is in spec so i checked the coil and the primary side was ok but when i followed the manuals way of checkin the secondary side by testing from the black side of the primary side to the either wire on the secondary side of the coil i got nothing .... and this was on two different coils .... so what im asking is does anyone know what voltage either ac or dc should i be seeing on the primary side of the coil coming from the cdi to rule out if i have a coil or a cdi problem..... thanx for any help.... i just finished my winter rebuild and im dying to ride..... please help a brutha out ...lol Quote Link to comment Share on other sites More sharing options...
jonnybanshee Posted April 11, 2010 Author Report Share Posted April 11, 2010 an the wiring is all good ..... Quote Link to comment Share on other sites More sharing options...
jonnybanshee Posted April 11, 2010 Author Report Share Posted April 11, 2010 oh yea an the tors is lone gone an ran fine after so.....yea im stumped guys... Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 11, 2010 Report Share Posted April 11, 2010 ok so i have a problem with my 88 shee.... i rode yesterday with no problems and then today i got to fire it up and it fired up for a second and died .... so i check for fuel and spark and found that i had no spark.... i check both the stator and pickup coil and everything is in spec so i checked the coil and the primary side was ok but when i followed the manuals way of checkin the secondary side by testing from the black side of the primary side to the either wire on the secondary side of the coil i got nothing .... and this was on two different coils .... so what im asking is does anyone know what voltage either ac or dc should i be seeing on the primary side of the coil coming from the cdi to rule out if i have a coil or a cdi problem..... thanx for any help.... i just finished my winter rebuild and im dying to ride..... please help a brutha out ...lol The manual is wrong on how to check the secondary side of the coil, the way the manual says to do it is for a typical coil that only has 1 wire or tower on it. The correct way to check a Banshee coil is to connect 1 lead from your meter to EACH one of the spark plug wires and see what you get.Check your magnets in the flywheel to see if they are ok, check the air gap on the pickup coil, it should be .017 inches or about the thickness of a matchbook cover. Ohm out the stator, pickup coil, and the coil, if they all check out, then borrow a CDI box from a buddy and see if it will run. According to the Yamaha manual, there is no way to check the CDI box, except by substituting another.You should also check the spark plug caps on the coil, they have a resistor in them that can go bad. Quote Link to comment Share on other sites More sharing options...
jonnybanshee Posted April 11, 2010 Author Report Share Posted April 11, 2010 The manual is wrong on how to check the secondary side of the coil, the way the manual says to do it is for a typical coil that only has 1 wire or tower on it. The correct way to check a Banshee coil is to connect 1 lead from your meter to EACH one of the spark plug wires and see what you get.Check your magnets in the flywheel to see if they are ok, check the air gap on the pickup coil, it should be .017 inches or about the thickness of a matchbook cover. Ohm out the stator, pickup coil, and the coil, if they all check out, then borrow a CDI box from a buddy and see if it will run. According to the Yamaha manual, there is no way to check the CDI box, except by substituting another.You should also check the spark plug caps on the coil, they have a resistor in them that can go bad. ah ok thanx...does anyone in the clio area wanna help a brutha out with a known good cdi box i can see if it works...hit me up 810 262 1560 Quote Link to comment Share on other sites More sharing options...
jonnybanshee Posted April 11, 2010 Author Report Share Posted April 11, 2010 ah ok thanx...does anyone in the clio area wanna help a brutha out with a known good cdi box i can see if it works...hit me up 810 262 1560 GEEZZZZ sorry guys about all the doube posting .... trying to reply by my cell phone suxs... but i figured that it is the cdi box.... seems like the prevous owner had did a little work to it .... seems like the the box took a good hit and had a good crack and broke a chip of it ... so someone tried to use silicone to seal it back up ... well i cut the cdi outta the box and it got some mositure into it and started to corrode..... sux ... oh well...a new cdi on the way ... Quote Link to comment Share on other sites More sharing options...
jonnybanshee Posted April 15, 2010 Author Report Share Posted April 15, 2010 GEEZZZZ sorry guys about all the doube posting .... trying to reply by my cell phone suxs... but i figured that it is the cdi box.... seems like the prevous owner had did a little work to it .... seems like the the box took a good hit and had a good crack and broke a chip of it ... so someone tried to use silicone to seal it back up ... well i cut the cdi outta the box and it got some mositure into it and started to corrode..... sux ... oh well...a new cdi on the way ... ok so i installed the new coil and cdi box .... still no spark .... check stator and its ohms out within specs no problem...and the pick up coil also is within specs.... idk what to do.... Quote Link to comment Share on other sites More sharing options...
Overboost Posted April 22, 2010 Report Share Posted April 22, 2010 ok so i installed the new coil and cdi box .... still no spark .... check stator and its ohms out within specs no problem...and the pick up coil also is within specs.... idk what to do.... no worries,I fixed it for him.....just outta tune was all.... Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 22, 2010 Report Share Posted April 22, 2010 More info, what exactly did you do? Thanks. Quote Link to comment Share on other sites More sharing options...
bode1 Posted April 22, 2010 Report Share Posted April 22, 2010 The manual is wrong on how to check the secondary side of the coil, the way the manual says to do it is for a typical coil that only has 1 wire or tower on it. The correct way to check a Banshee coil is to connect 1 lead from your meter to EACH one of the spark plug wires and see what you get.Check your magnets in the flywheel to see if they are ok, check the air gap on the pickup coil, it should be .017 inches or about the thickness of a matchbook cover. Ohm out the stator, pickup coil, and the coil, if they all check out, then borrow a CDI box from a buddy and see if it will run. According to the Yamaha manual, there is no way to check the CDI box, except by substituting another.You should also check the spark plug caps on the coil, they have a resistor in them that can go bad. Do you need special plug caps or will anyone from an auto parts store work? Quote Link to comment Share on other sites More sharing options...
jonnybanshee Posted April 23, 2010 Author Report Share Posted April 23, 2010 Do you need special plug caps or will anyone from an auto parts store work? im pretty sure u need to use the 5k ohm caps.... but i swapped cdi boxes an trailered it over to his house and it fired....lol he tuned her in good...other than that havnt had a problem... just working on the jetting and its golden .... alil rich off the bottom...i think my pilot maybe too rich like u said overboost... thanx again for showing me again bro!! Quote Link to comment Share on other sites More sharing options...
