Ok so i havent been on much latey an decided to start working on the shee again. so far ive put a brand new top end rebuild on her an then i also went from the 2 to 1 carb setup also all brand new. an for some reason now when i start her she only fires right on the left cylinder. i put new plugs an switched the reeds around an even the plug wires to see if i had them backwords an nothing helped. could it be an air leak or maybe a timing issue. i also discovered that there is a solid white wire that comes out of the stator that is cut an tapped off an goes no where. ive check in my book an it shows there shouldnt be a white wire anywhere. im so confused on what to do next.
by the way its an 89 shee if that will make any difference..
thanks gays/gals
Bob
