jacquesraney Posted April 8, 2010 Report Posted April 8, 2010 when i take of the cap and rev it up... it seems to move around pretty good,, can't really tell if its from vibration though,,, when I felt the actuall radiator it felt hot.. wich led me to belive that it is flowing properly.... the last flush was 20 hrs ago... thnks.. also how hard is a new impellar to install and what would you recomend??? Quote
TwistedSheeRida Posted April 8, 2010 Report Posted April 8, 2010 Yeah if the coolant is moving when you pull the cap then its working. Are you having problems with it overheating? chariot makes a nice billet impeller and they are not that hard to install at all. You will have to get a new clutch cover gasket and i would change out the bearing and seal in there too. Quote
