frog Posted April 5, 2010 Report Share Posted April 5, 2010 I just installed a set of .40 vito's superstock pistons I also installed the jet kit that vito's sell for the piston kit.I am running 320 mains and 35 pilots and needles on the 3rd clip.My bike has no bottom end but hit a little at half throttle and wont hit at top end either ,my plug looks good.My shee has fmf gold series pipes and dual k&n filters,v force reeds.No porting.My compression is at 135psi.Would raising the need and droping the pilot help? Thanks Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 5, 2010 Report Share Posted April 5, 2010 I had 310 mains.. stock needles on 4th clip (from blunt end) and pilots were 27.5's.. Motor had T-5's, K&N, and VF2's.. Compression was 135ish and elevation was around 500ft. Hope this helps. Quote Link to comment Share on other sites More sharing options...
frog Posted April 5, 2010 Author Report Share Posted April 5, 2010 So why does vito say you must use the jet kit for the superstock pistons.They are the same needles in the stage 3 dynojet kit.And the vito's jet kit only comes with the 35 pilot jet and I thought these pilots were way to rich.Does your bike still pull hard with the superstock pistons.Also I'm at 950 elevation. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 5, 2010 Report Share Posted April 5, 2010 So why does vito say you must use the jet kit for the superstock pistons.They are the same needles in the stage 3 dynojet kit.And the vito's jet kit only comes with the 35 pilot jet and I thought these pilots were way to rich.Does your bike still pull hard with the superstock pistons.Also I'm at 950 elevation. Bike ran like a champ.. Not a problem out of it.. Pulled from bottom to top. Quote Link to comment Share on other sites More sharing options...
frog Posted April 5, 2010 Author Report Share Posted April 5, 2010 Do you think it could just be the pilots being to rich,I'll try size 30 pilot jets tomorow and move the needles to the forth clip and see if that does anything to improve the bikes performance. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 5, 2010 Report Share Posted April 5, 2010 Do you think it could just be the pilots being to rich,I'll try size 30 pilot jets tomorow and move the needles to the forth clip and see if that does anything to improve the bikes performance. yah.. I'm sure that pilot is gonna be fat. Lean back and see if it clears up. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted April 5, 2010 Report Share Posted April 5, 2010 I bet a 27.5 pilot would be about right, I also think your main jet is to big. Most jet kits are a rip off, because they are the jets that work at the elevation and riding area of the vendor and don't take into account antwhere else. Quote Link to comment Share on other sites More sharing options...
frog Posted April 5, 2010 Author Report Share Posted April 5, 2010 Well the 30 pilots clean it up and 290 main letting her pull right to the end.The guy at vito's said that the pilot size they include in there kit is a starting point,but they don't included the smaller sizes pilots but give you 340 down to 290 mains.It's to bad that you can't just buy the needles.Oh! ya ,thanks for the answears to my questions this site rocks. Quote Link to comment Share on other sites More sharing options...
