SLORYDER Posted March 30, 2010 Report Posted March 30, 2010 Just curious I know you can get a drag port close to the hp of a stock cub but how do the powerbands compare? Seems like the stock cub would have a broader range but I really have no clue Thanks Quote
firebanshee Posted March 31, 2010 Report Posted March 31, 2010 Just curious I know you can get a drag port close to the hp of a stock cub but how do the powerbands compare? Seems like the stock cub would have a broader range but I really have no clue Thanks The cub has a VERY peaky powerband out of the box. Quote
SLORYDER Posted March 31, 2010 Author Report Posted March 31, 2010 So a drag ported stocker is not? Quote
stclark816 Posted March 31, 2010 Report Posted March 31, 2010 I have had both, and in my opinion, there is no comparison. Quote
sheefreak Posted March 31, 2010 Report Posted March 31, 2010 If you are asking where at in the RPM range each makes its power, a cub and a drag ported cylinder are very similar. You will be hard pressed to make the same power on a stock cylinder as you can easily make w/a cub(i believe this is what the other guys are referring too). Quote
