Husemoller Posted March 30, 2010 Report Share Posted March 30, 2010 Hey guys, Just got in couple used carbs that have tors removed on it. Took them apart and cleaned them a little bit. But got a couple questions. First what does this screw do on the left? I took it out and cleaned everything up but curious on how I should know how far to screw it in. and then this would be the air/fuel mixture screw right? which I would turn all the way in and then turn out about 1 1/2 turns and just go from there? my machine is stock besides a k and n air filter Thanks guys Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted March 30, 2010 Report Share Posted March 30, 2010 In the first picture, thats your air/fuel screw The second picture is your idle adjustment. Check out the jetting forum, they are a couple good threads that will help you out with jetting and tuning your carbs http://bansheehq.com/forums/index.php?showforum=4 At the top, there are a few you should read through. Quote Link to comment Share on other sites More sharing options...
Husemoller Posted March 30, 2010 Author Report Share Posted March 30, 2010 alright cool thanks man also the float area cover that comes off with 4 screws. Is the one with the little jet in there the one for the carb with the choke??? I am positive i didnt mix them up but for some reason the one with the jet was on the carb without the choke. Just want to make sure I got them right. Quote Link to comment Share on other sites More sharing options...
Husemoller Posted March 30, 2010 Author Report Share Posted March 30, 2010 nevermind just found a thread with exactly what i was looking for Quote Link to comment Share on other sites More sharing options...
