Hey guys, Just got in couple used carbs that have tors removed on it. Took them apart and cleaned them a little bit. But got a couple questions.
First what does this screw do on the left? I took it out and cleaned everything up but curious on how I should know how far to screw it in.
carbphoto2
and then this would be the air/fuel mixture screw right? which I would turn all the way in and then turn out about 1 1/2 turns and just go from there? my machine is stock besides a k and n air filter
carbphoto
Thanks guys
alright cool thanks man
also the float area cover that comes off with 4 screws. Is the one with the little jet in there the one for the carb with the choke??? I am positive i didnt mix them up but for some reason the one with the jet was on the carb without the choke. Just want to make sure I got them right.
