Are the wiring harnesses on the older and newer style banshee's the same except for the connectors? I want to change out the electric on my banshee. Thanks
Yes, pretty much the same except connectors. They added a few things as the years progressed, like the brake-light switches on the brake levers on the newer years. But the main harness itself hasn't changed much.
Thank you. Is there any place to get OEM harnesses for the older style?
CheapCylceParts.com
RideNow Powersports
Apache MOtorcyles
These are the cheapest sources for OEM parts that I know of. If they don't have it in stock they can get it quickly. their sites all have an OEM parts lookup and you can get parts for most makes from any of them.They all have websites you can order from. The harnesses are broken into 4 groups: 87-94 which have the round plugs, 95-95 which have square plugs, 97-01 which have the square plugs and the wire for the park brake rev limiter, and 02-06(in USA) that have the square plugs, park brake rev limiter AND brake light wiring. I also believe that the terminals inside the plugs are different between the round and square plugs.
