SLORYDER Posted March 26, 2010 Report Posted March 26, 2010 Ok it's gonna be on a fully drag ported 350 w/ 34mm carbs/ cpi pipes j arm frame with 160 lb rider. Also gonna be that heavy sand with the little bitty pebbles in it (LA Dunes) Thanks Quote
SLORYDER Posted March 26, 2010 Author Report Posted March 26, 2010 Also not sure the gearing but the guy says it is geared to run right at 100mph in 6th and I believe the front sprocket is a 15 or a 16 Quote
RadarRacing Posted March 26, 2010 Report Posted March 26, 2010 Need more info. On alky or out of frames will pull more tire and need more arm. On gas and inframes to play and dune a +6 and 9 or 10 paddles. Quote
SLORYDER Posted March 26, 2010 Author Report Posted March 26, 2010 Need more info. On alky or out of frames will pull more tire and need more arm. On gas and inframes to play and dune a +6 and 9 or 10 paddles. Inframe pipes. Pump gas I have a +8 and some 11 paddle tripple buffs right now but I run tubes in 'em and don't know if I can get the pressure low enough top bite outa the hole.. Quote
RadarRacing Posted March 26, 2010 Report Posted March 26, 2010 Probably a +6 then and a 10 paddle extreme since the jocky is light. That's what my buds and I ran for years and had fun dune racing. If you use an 8 over you'll wanna run 11s probably. Quote
randomrider Posted March 27, 2010 Report Posted March 27, 2010 i wouldnt get your hopes up on it running 100 mph Quote
SLORYDER Posted March 27, 2010 Author Report Posted March 27, 2010 I'm sure with the mods listed I could easily run 100 mph on asphault I was just giving you a rough estimate of my gearing. Seems like a +8 would be short for dragging I could be wrong though.... Quote
