krauss4 Posted March 25, 2010 Report Posted March 25, 2010 i just got a cheetah motor and it has a lockup clutch on it and i noticed that it shifts kinda hard and when i put it in gear nd pull the clutch in and rev it up it wants to move a little bit. i have adjusted the clutch to where it pulls allthe way in and still wont stop n e ideas? Quote
01banch Posted March 25, 2010 Report Posted March 25, 2010 does it have a billet basket? the walking you are describing could be caused by deep grooves in the clutch basket not letting the clutch to disengage. Quote
SD1026 Posted March 25, 2010 Report Posted March 25, 2010 what kind of springs do you have all hd springs all stock half and half???is your cable streched out ? did you line up the arrow on the cases? Quote
krauss4 Posted March 25, 2010 Author Report Posted March 25, 2010 it has heavy springs in it i dont think its the cable bc i just changed the motor out and the old motor didnt do it. would deep grooves in the basket cuse it to shift hard too? Quote
bansheesandrider Posted March 25, 2010 Report Posted March 25, 2010 it has heavy springs in it i dont think its the cable bc i just changed the motor out and the old motor didnt do it. would deep grooves in the basket cuse it to shift hard too? If it has a lockup clutch and does not have an override tranny, it is going to shift hard. Quote
SD1026 Posted March 25, 2010 Report Posted March 25, 2010 If it has a lockup clutch and does not have an override tranny, it is going to shift hard. i think his banshee is creeping with the clutch pulled in. also if its slamming into first and you can hear the shifting forks getting bashed i think thats sorta bad Quote
