Nope. Bolt them up and run it.
Changing out my intakes and my new one's don't have the hole for the cross over tube. Do you need to have a cross over tube?
If you don't have a crossover tube, you need to make sure your carbs are synced PERFECTLY. The purpose of the crossover tube is to balance out any differences in flow from one side of the engine to the other. If you are not running a crossover or balance tube then I would definitely get the sync tool from FAST abd use it.
