9banshee6 Posted March 19, 2010 Report Posted March 19, 2010 how and what do i clean my carbs with? Quote
overrevtricky Posted March 19, 2010 Report Posted March 19, 2010 I pull em off the bike, break em down, pull all the jets out, blow em out, then clean it with Gumout Carb and choke cleaner. That stuff seems to work best for me. Quote
goinggolfn Posted March 19, 2010 Report Posted March 19, 2010 how and what do i clean my carbs with? After 20+ years of working on these machines, a great tip is to let the carbs soak overnight in sometype of cleaner, this breaks up any dirt that becomes clogged in any orfice or jet. Then blow it out with carb cleaner, and last air. good luck Quote
SAVAGE420 Posted March 19, 2010 Report Posted March 19, 2010 how and what do i clean my carbs with? Take the carb caps off, pull the bowls off, take out all jets, you can use carb cleaner inside if you like( i dont), then use compressed air to clean out ALL passages (fuel circuits) inside and the jets also. Check to see if your floats are set to the correct hight and so on. Reassemble! Quote
9banshee6 Posted March 20, 2010 Author Report Posted March 20, 2010 Take the carb caps off, pull the bowls off, take out all jets, you can use carb cleaner inside if you like( i dont), then use compressed air to clean out ALL passages (fuel circuits) inside and the jets also. Check to see if your floats are set to the correct hight and so on. Reassemble! how high are the floats supposed to be? Quote
SAVAGE420 Posted March 20, 2010 Report Posted March 20, 2010 how high are the floats supposed to be? 20-22mm! Quote
