-Herbie- Posted March 19, 2010 Report Posted March 19, 2010 i read the entire post on jetting with everyone's specs, very helpful. I've jetted my yfz a bunch of times but this is my first banshee. So i would like to get a couple suggestions for starting point cause I didn't see any indication how cool head affects jetting. Here are my specs. 1)FMF Fatty's w/PowerCore Silencers 2) K&N 2-1 filter 3) Stock box no lid or snorkel 4) 600 ft 5) Pilots??? 5a) Needle??? 6) Main??? 7) 60-80 Degrees 8) No porting 9) What kind of carbs? Mikuni 10) What size carbs? Stock 11) Cool head w/20cc Quote
GrMeyer Posted March 19, 2010 Report Posted March 19, 2010 Start with Mains - 300 Needle - Middle Pilot - 27.5 Air Screw - 1-1/2 turns out from fully seated. Shoulder get you started. Read up on this site as well http://www.dfn.com/benkaren/jetfaq.html Make sure your carbs are synced or you will have one shitty bottom end. Have fun!!! Quote
Rodneya Posted March 19, 2010 Report Posted March 19, 2010 A cool head is not much of a performance mod. It has zero effect on jetting. Quote
-Herbie- Posted March 19, 2010 Author Report Posted March 19, 2010 A cool head is not much of a performance mod. It has zero effect on jetting. the extra compression from 24 to 20 cc domes doesn't require more fuel? Thanks GR ill start with that Quote
GrMeyer Posted March 19, 2010 Report Posted March 19, 2010 No it will not take in more fuel. Only if you can keep from running WOT all the time. Its only compressing the fuel that is already used to be more efficient. When I went from a stock head to 20cc domes. There was no change in fuel intake. IE jetting. The only thing I did change was from burning 91 pump. I know run a 50/50 mix of 91 and 100ll. But my bike does run cooler with the head. There is a nice little mod that you can do for really cheap. I just used some old weather seal to help keep the air from going around the rad. If you look at the front of the bike. There is almost a inch gap on both side of the rad. Sealing that so the air will only go through the rad is a big improvement on staying cool. Quote
