2001 Banshee for sale
I’m selling my 2001 Banshee with title in hand. I recently purchased this banshee to do a ground up build, can no longer continue with it, my wife and I have a baby on the way. Chassis has been glass bead blasted and sprayed with single stage self-etching primer, ready to paint. Every part has been cleaned in a solvent parts washer and bagged with label. I have receipts for everything that has been done to the engine and quad, .020 Over wiseco pistons, white brothers boost bottle, pro design ez drain, idle kit, motion pro twist throttle, rear shock cover (black), fmf fatty sst pipes and silencers, Toomey radiator, ufo front fender ( race cut), Maier rear fender (both black), pro design kill switch, pro design billet water impeller, 14 tooth front sprocket, mikuni tmx 34mm carbs, upp 34mm intake manifolds, pingle fuel valve, billet banshee engraved bar clamp with billet aluminum key, renthal bars, hyper carbon fiber single bead lock front wheels with ITP Holeshot tires, hyper cf dual bead lock rear wheels and Itp holeshot rear tires, 2 k&n filters with red outerwears, ac swingarm skid plate, prm full chassis skid plate, clark high capacity black fuel tank, chrome billet front grill, silver vein powder coated steering stem, v force carbon fiber reeds. Toomey clutch disks (clutch pressure plate and rear clutch plate will need replaced worn out). Bought this as a running quad tore it down to build a wild machine, time and also money is a big factor now I have a little man on the way I hate to let this go. I’m asking $1,500 for everything. Must pick up at my house, will cost too much to ship. If it does not sell let me know what you want and I will part it out.
Cylinder jugs are cylindrical within .001. Used inside micrometers to check for roundness and taper. I was going to lightly hone the cylinders there are a few scratches in one of the jugs, only a few microns deep, honing isn’t required but was going to go ahead and hone them anyways. The parts on this banshee are high quality parts and will make a killer banshee.
Im located in Enon, Ohio and the best number to contact me is on my cell phone @ 937-831-0327. If you cant reach me there you can call my shop number at 937-340-6135. Thanks, Aaron
Hyper carbon-fiber beadlock wheels are sold.
Talked it over with my wife and decided to part the banshee out.
1.Glass beaded and sprayed with single stage dupont primer $200
2. Boost bottle $5
3. Pro design EZ drain $10
4. Motion pro twist throttle $30
5. Toomey radiator/ has broken mount tab $45
6. FMF SST fatty pipes/silencers $200
7. Front reat fenders $75 for both also includes tank cover and chrome billet grill or $45 each
8. 34mm Tmx car/k&n filters and outerwears $125
9. Clark 5.5 black fuel tank with pingle valve $45
10. Silver vein powder coated steering stem with pro design kill switch, renthal handle bars and billet banshee bar clamp, billet brake resevoir cover $100
11. AC swingarm skid plate $30
12. PRM full chassis skid plate with hardware $50
13. Engine case and internal parts. Everything minus clutch and piston rings. Not assembled will include red-line assembly lube and new gasket and seal kit, billet hinson clutch cover, billet water pump cover, billet dipstick $475
I have plenty of parts left over going cheap. I still have
1. Engine case $ 80
2. Rear stock shock $ 45
3. Rear wisbone $15
4. Powder Coated steering stem with renthal bars motion pro twist throttle, billet brake resevoir cover, and tie-rods in good shape. $ 75
5. FMF SST Fatty pipes with power core 2 silencers $ 185
6. Glass bead blasted chassis with dupont single stage primer Title in hand!!! $ 150
7. Stock crank rod clearance between throws .016 $ 100
8. Trinity stage IV billet head with domes $100
9. Cylinders left and right may need very light hone, they mic'd out with in .001 cylindricity $ 75 for both
10. Entire engine gasket kit brand new still in package from F.A.S.T $ 25
11. Seal kit brand new still in package from F.A.S.T $ 15
12. Stock flywheel, stator, and pro design adjustable timing plate $ 50
13. Rebuild transmission with shift drums and forks , assembled with red line assembly lube $50
14. PRM Full chassis skid plate w/ mounting hardware $ 50
15. AC Racing rear grab bar with rear tail light $ 30
16. Front stock hubs with brake rotors $ 40 for both
17. Front and rear brake calipers $ 40 for all 3
18. Roll design black and chrome pegs $50
19. AC Nerf bar with black nets $30 > are a little rough, could use some emry clotch and scotch brite and then will buff to a shine.
20. Black seat no tears or rips $45
21. Coolant overflow rear mount, aluminum $ 20
22. Hide a key mount chrome with fuel primer $ 20
23. Clarke 5.5 gal high capacity fuel tank no fuel pet cok $ 40 (BLACK)
24. Aftermarket head lights chrome $ 35 for the pair
25. Front bumper, AC? or DG , $ 30
24.
can you pm me pics of this stuff...thanks! :cheers:
ill take some pictures now. could i send them to your email
2. Boost bottle $5
