hartracing3478
Everything posted by hartracing3478
  1. Everything has been sold except the STOCK gas tank, i stand corrected on that, it was purchased as a clarke 5.5 and turns out its a stock tank. I will probally toss that. Other than that all i have left is the engine case, tranny, stock crank, front bumper, rear grab bar and thats about it thanks for everyone looking and making offers. For the ones who purchased parts your shipment will ship in about 1 hour, ups truck is on its rounds. I will pm you your tracking number. thanks again
  2. ill take some pictures now. could i send them to your email
  3. I have plenty of parts left over going cheap. I still have 1. Engine case $ 80 2. Rear stock shock $ 45 3. Rear wisbone $15 4. Powder Coated steering stem with renthal bars motion pro twist throttle, billet brake resevoir cover, and tie-rods in good shape. $ 75 5. FMF SST Fatty pipes with power core 2 silencers $ 185 6. Glass bead blasted chassis with dupont single stage primer Title in hand!!! $ 150 7. Stock crank rod clearance between throws .016 $ 100 8. Trinity stage IV billet head with domes $100 9. Cylinders left and right may need very light hone, they mic'd out with in .001 cylindricity $ 75 for both 10. Entire engine gasket kit brand new still in package from F.A.S.T $ 25 11. Seal kit brand new still in package from F.A.S.T $ 15 12. Stock flywheel, stator, and pro design adjustable timing plate $ 50 13. Rebuild transmission with shift drums and forks , assembled with red line assembly lube $50 14. PRM Full chassis skid plate w/ mounting hardware $ 50 15. AC Racing rear grab bar with rear tail light $ 30 16. Front stock hubs with brake rotors $ 40 for both 17. Front and rear brake calipers $ 40 for all 3 18. Roll design black and chrome pegs $50 19. AC Nerf bar with black nets $30 > are a little rough, could use some emry clotch and scotch brite and then will buff to a shine. 20. Black seat no tears or rips $45 21. Coolant overflow rear mount, aluminum $ 20 22. Hide a key mount chrome with fuel primer $ 20 23. Clarke 5.5 gal high capacity fuel tank no fuel pet cok $ 40 (BLACK) 24. Aftermarket head lights chrome $ 35 for the pair 25. Front bumper, AC? or DG , $ 30 24.
  4. Hyper carbon-fiber beadlock wheels are sold. Talked it over with my wife and decided to part the banshee out. 1.Glass beaded and sprayed with single stage dupont primer $200 2. Boost bottle $5 3. Pro design EZ drain $10 4. Motion pro twist throttle $30 5. Toomey radiator/ has broken mount tab $45 6. FMF SST fatty pipes/silencers $200 7. Front reat fenders $75 for both also includes tank cover and chrome billet grill or $45 each 8. 34mm Tmx car/k&n filters and outerwears $125 9. Clark 5.5 black fuel tank with pingle valve $45 10. Silver vein powder coated steering stem with pro design kill switch, renthal handle bars and billet banshee bar clamp, billet brake resevoir cover $100 11. AC swingarm skid plate $30 12. PRM full chassis skid plate with hardware $50 13. Engine case and internal parts. Everything minus clutch and piston rings. Not assembled will include red-line assembly lube and new gasket and seal kit, billet hinson clutch cover, billet water pump cover, billet dipstick $475
  5. I'm having problems uploading pictures either there too big or to small . I will gladly email pictures or specific pictures of parts to emails. Thanks
  6. I’m selling my 2001 Banshee with title in hand. I recently purchased this banshee to do a ground up build, can no longer continue with it, my wife and I have a baby on the way. Chassis has been glass bead blasted and sprayed with single stage self-etching primer, ready to paint. Every part has been cleaned in a solvent parts washer and bagged with label. I have receipts for everything that has been done to the engine and quad, .020 Over wiseco pistons, white brothers boost bottle, pro design ez drain, idle kit, motion pro twist throttle, rear shock cover (black), fmf fatty sst pipes and silencers, Toomey radiator, ufo front fender ( race cut), Maier rear fender (both black), pro design kill switch, pro design billet water impeller, 14 tooth front sprocket, mikuni tmx 34mm carbs, upp 34mm intake manifolds, pingle fuel valve, billet banshee engraved bar clamp with billet aluminum key, renthal bars, hyper carbon fiber single bead lock front wheels with ITP Holeshot tires, hyper cf dual bead lock rear wheels and Itp holeshot rear tires, 2 k&n filters with red outerwears, ac swingarm skid plate, prm full chassis skid plate, clark high capacity black fuel tank, chrome billet front grill, silver vein powder coated steering stem, v force carbon fiber reeds. Toomey clutch disks (clutch pressure plate and rear clutch plate will need replaced worn out). Bought this as a running quad tore it down to build a wild machine, time and also money is a big factor now I have a little man on the way I hate to let this go. I’m asking $1,500 for everything. Must pick up at my house, will cost too much to ship. If it does not sell let me know what you want and I will part it out. Cylinder jugs are cylindrical within .001. Used inside micrometers to check for roundness and taper. I was going to lightly hone the cylinders there are a few scratches in one of the jugs, only a few microns deep, honing isn’t required but was going to go ahead and hone them anyways. The parts on this banshee are high quality parts and will make a killer banshee. Im located in Enon, Ohio and the best number to contact me is on my cell phone @ 937-831-0327. If you cant reach me there you can call my shop number at 937-340-6135. Thanks, Aaron
  7. No problem. Got it boxed up with the bolts and the castle nuts. Ready to ship tomorrow morning. Thanks again.
  8. I have a Lonestar chrome extended axle for sale with billet sprocket and brake hub. It measures 39" from end to end. In excellent shape. Cleaned in solvent tank and inspected on v-blocks with travel indicator to check for T.I.R. Axle is straight. $285 shipped. Any questions feel free to email me at [email protected]. Or at 937-831-0327
  9. looking for woods. i do alot of trail riding
  10. I can send pictures to an email address. thanks Brand new completely restored cannondale 440. Engine has been completely rebuilt from the ground up by Black Widow ATV. All updates have been done. Brand new maxis razr tires and black powder coated ITP front and rear wheels. Full HMF exhaust system. All new bearings from All Balls Racing and stainless steel hardware. Every single thing on this quad has been replaced. Over $10,000 invested. Two sets of plastic. One set is an FX 400 Charcoal gray that has never been mounted and still in its box. A set of red plastic that has wet sanded and prepped for paint. Aluminum propeg AC nerfbars with stainless steel rear guards. Gold anodized tag aluminum handlebars. Two sets of Cannondale grips. Two spair throttle cables. Jet hot-coated exhaust pipe, radiator, front bumper and rear axle. Spare brake pads. Black powder coated side cover. Powder coated clutch cover. Brand new air box with k&n filter.
