Got super lucky and scored some FMF Fatty's and PowerCore 2's for $100 on Epay.
I have owned my Bansh since 1988 and it has had stock exhaust until now. It currently has no airbox snorkel (but has lid on) and a K&N filter with outer wrap. I ride at 600 to 1000 feet and usually 60-80 degrees. I have 220s in now with stock pilot. I have dialed this in over the years and it is right on around 65 degrees. I run 32:1 yamalube R.
So FMF recommends 260s with a 30 pilot - stock airbox no snorkel.
I looked through the long jetting poll and some people with similar configs look to be running up to 330! But others are running 270. That is a pretty big variance.
What do you all think. I was going to put in 270s to start.
i would start at 300 and work your way down , you might need 27.5 pilots
It depends on if you want to run the lid or not.
With the lid
Mains - 310
Needle - Middle
Pilot - 27.5
Air Screw - 1-1/2 Turns from fully seated
With the lid
Mains 270
Needle - Middle
Pilot - 27.5
Air Screw - 2 turns out from fully seated.
All this is a starting points. Each bike is different from one another. But those should get you close for starting.
Read up on this site as well if you havent already.
http://www.dfn.com/benkaren/jetfaq.html
Ok, thanks all.
I think I am going to go ahead and start with the 270s. I mostly trail ride and there is water and a lot of dust at times so I plan on keeping the airbox lid on. Plus I have some 270s. I also have some 260s but looks like I need to order up a few fatter jets as it looks like I will be going richer, if anything.
After I get them in and take it for a run I'll report back on how close they are.
Ok, thanks all.
I ride in Kansas and at LS OKLA. I have FMF Gnarly's w/Power Core II silencers. I end up with 290's in 40-60 degree weather w/lid, 280's in 70-90 degrees w/lid and usually pull the air box lid above 90's rather than rejet
  • 2 weeks later...
OK, got my pipes on. I put the 270s in with the 130 pilots.
Boy, the pipes sure woke up my shee! Ran great, for sure the power comes on sooner and harder. Shoot, I have had the banshee for 22 years - should have put pipes on long ago.
Anyway, riding in the woods behind my house it seems fine. Was about 60 degrees. I don't think it is running rich for sure. Ran it at WOT on the road on the way back and it made a lot of power but didn't feel lean. However, I may bump up to the 280s just to be safe.
