Yea, I was going to start there and see what that does. I may end up dropping one on the pilot too.
Here's my current settings
4 mil stroker with aggressive dune port from FAST (20 over)
CPI inframes
35mm PWK with CEL needles, clip dropped one from the middle position, 165 main jets, 52 pilots, air screws 1 turn out from seated
K&N pods
plus 4 timing
V force 3 reeds
Boss intake
Noss head- 20cc domes @ 185 psi
800 feet above sea level, 60-60 degrees out
I would leave the Pilots due to that fact that your only one turn out from fully seated. Just try turning counter clock to lean it out. But that will only be from idle-1/4 throttle that the air screws and pilots effect.
Hey man thanks a lot for the help! It's always nice when someone chimes in with a no bull and to the point answer! So I'll get out there and back the air screws off 1/2 turn at a time. I'm also going to raise the clip one notch to lean out the mids a tad.
