I re-posted this under a more descriptive title now that I found out whats wrong, I am going to re-place this bearing but I need to know a few thing. first will this puller work http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95987&xcamp=google&utm_source=googlebase&utm_medium=cpc&zmam=13262200&zmas=12&zmac=112&zmap=95987 also How do I take this apart do I losen the clutch springs to slide this arm out so on and so on? how many bearings are in there I have a 1999 banshee is there 2 or 1? thanks
I think any bearing removal tool will be fine. I use the motion pro set. They all basically work th same, by putting a plug in the bearing. Then you use a rod with a tappered end and slide it into the groove on the plug and tap it in place to "spread" the plug. Then you tap the bearing out. Some bearing you have to hit harder than others. Becarful on the cases, they can break pretty easy if you get it in a bind and start knocking the piss out of it.
To put it back in use the plug and tap it in place until it bottoms.
