Jayy Posted March 13, 2010 Report Posted March 13, 2010 Hi guys. I have a stud that is stripped on the rear sprocket hub of my shee. Can the stud be removed and replaced? I have the nut off, but cannot telol if I can remove the stud frodm the hub or not. If so, how? Thanks for your help. Quote
Jayy Posted March 13, 2010 Author Report Posted March 13, 2010 I dont know if I can press them out or not. The studs look like they may be threaded into the hub? Quote
SD1026 Posted March 13, 2010 Report Posted March 13, 2010 I dont know if I can press them out or not. The studs look like they may be threaded into the hub? They are threaded inthe hub. The seel a socket with reverse threads inside that takes them out not sure of the name but I know many mechanics have the set. Quote
Jayy Posted March 13, 2010 Author Report Posted March 13, 2010 They are threaded inthe hub. The seel a socket with reverse threads inside that takes them out not sure of the name but I know many mechanics have the set. Thats what I was afraid of. I guess I will have to figure out the thread size, then I can see about getting one of those. Thanks guys. Quote
SD1026 Posted March 13, 2010 Report Posted March 13, 2010 Thats what I was afraid of. I guess I will have to figure out the thread size, then I can see about getting one of those. Thanks guys. Its called a stud remover socket. But if its stripped u can just use a good set of needle nose viscripes unless its in there pretty good. Quote
sleeper06 Posted March 13, 2010 Report Posted March 13, 2010 I could never find replacements around by me but I used a forein car stud and tacked it in.Try going to bike bandit and looking at a picture of it to see if you can order it ,or the hubs are a dime a dozen im sure someone has one laying around for cheap Quote
robert.b.west Posted March 14, 2010 Report Posted March 14, 2010 Take a blow torch and heat one up for like 20-30 seconds then take some vice grips and turn the stud. I stripped mine out trying to get them off but as soon as I put some heat on the bolts they come right out. Quote
