White97Banshee Posted March 12, 2010 Report Posted March 12, 2010 I just got a new heavy duty clutch kit from cascade and i've heard that with those kits i'm supposed to keep 3 of the factory springs and do every other one with the heavy duty springs it came with, is that true? or do I just put all 6 of the HD springs in? Quote
Burt Reynolds Posted March 12, 2010 Report Posted March 12, 2010 You could do either really in my opinion. i would use at least 3 of each but if you got strong hands throw em all in and see if its too rough Quote
White97Banshee Posted March 12, 2010 Author Report Posted March 12, 2010 Would it be hard on the clutch cable to use all 6? If not I think I'll just toss em all in.. Quote
GrMeyer Posted March 12, 2010 Report Posted March 12, 2010 Everything stretches. If its and old cable, it should already be stretched. I have tried the 6hd springs and it was hard as hell and not fun to pull the clutch in. So i went back to 3&3. Have been running it for about two years now with nothing bad to say. But if you have some Popi arms. Go ahead and try the 6. But just think back on how much you really shift when you are riding the dunes. Quote
bansheesandrider Posted March 12, 2010 Report Posted March 12, 2010 I run 3+3 in my Toomey setup, it depends on the springs and your hand. All 6 will be that much more stress on the cable, clutch ball, etc. when the clutch is pulled. My setup has been working fine for 15 years and there is no clutch slippage at all. Quote
GNR101 Posted March 12, 2010 Report Posted March 12, 2010 i run 6 H/D springs... its not that hard to pull Quote
Motoman991 Posted March 12, 2010 Report Posted March 12, 2010 I tried 6 HD springs in my banshee. I was also using a dirt bike clutch lever so it was a little shorter. 6 HD springs was way too hard to pull in. I put it to 3 and 3. Quote
papa_smurf49319 Posted March 13, 2010 Report Posted March 13, 2010 6 hd springs here also. New cable and clutch lever and perch, not bad at all to pull all 6 Quote
White97Banshee Posted March 13, 2010 Author Report Posted March 13, 2010 Alright cool I'll experiment both ways and see what I like best, thanks guys! I got the old clutch taken apart right now but I can't put the new one on till tomorrow cuz I gotta go to a dealer and pick up a clutch hub holding tool so I can take the hub off to install my new modded shift star. Can't wait to get it all back together! Quote
GrMeyer Posted March 13, 2010 Report Posted March 13, 2010 i run 6 H/D springs... its not that hard to pull Just only pulling for starts and stops I see. I do alot of quick down shifting in the dunes. So the clutch only really gets pulled for starts, easy riding and stopn, That is if I remember to use the damn thing. Quote
