drbanshee Posted March 4, 2010 Report Posted March 4, 2010 I got a 99 banshee fresh rebuilt with wiseco stock bore pistons, 4mil crank 110 rods and spacer, v-3 reeds, 35mm milkuni carbs, 370 main jet, 41 pilot, port and polished, and shearer small bore drag pipes. For some reason the powerband wont kick in, I moved the timing to 3, 4, 5, and 6., and I still dont got powerband. The bike starts on the first kick, idles good. Can anybody please give me any ideas on what the problem is. Thankyou. Quote
boneyardbanshee. Posted March 4, 2010 Report Posted March 4, 2010 I would be real careful on moving your timming up trying to fix a problem. Can you give some feedback on how it acts when riding. How it sounds, is it bogging, hows your clutch look? Carbs clean and adjusted properly? Air filter clean? Quote
boneyardbanshee. Posted March 4, 2010 Report Posted March 4, 2010 Another thing I noticed, it is freshly rebuilt with "stock bore" pistons? Can you elaborate on that? Not seeing how that can be right unless they have been resleeved. Quote
shakar Posted March 4, 2010 Report Posted March 4, 2010 (edited) I got a 99 banshee fresh rebuilt with wiseco stock bore pistons, 4mil crank 110 rods and spacer, v-3 reeds, 35mm milkuni carbs, 370 main jet, 41 pilot, port and polished, and shearer small bore drag pipes. For some reason the powerband wont kick in, I moved the timing to 3, 4, 5, and 6., and I still dont got powerband. The bike starts on the first kick, idles good. Can anybody please give me any ideas on what the problem is. Thankyou. mikuni 41 pilot?? aint that a keihin jet #?? Edited March 4, 2010 by shakar Quote
drbanshee Posted March 4, 2010 Author Report Posted March 4, 2010 I would be real careful on moving your timming up trying to fix a problem. Can you give some feedback on how it acts when riding. How it sounds, is it bogging, hows your clutch look? Carbs clean and adjusted properly? Air filter clean? The bike is running rich, it runs good it has power and doesnt backfire. Yes the cardbs are clean, and I just put a new k&n filters on it. What do you recomend on timing. Quote
boneyardbanshee. Posted March 4, 2010 Report Posted March 4, 2010 +4 is what most people on here reccomend for pump gas. If it is running rich it is more than likely in your carb adjustments I am sure someone who has a closer setup will be able to help with that. Quote
smokin 421 Posted March 6, 2010 Report Posted March 6, 2010 if u know ur rich start there lean it out or u will never hit the power band Quote
