9banshee6 Posted February 27, 2010 Report Posted February 27, 2010 say im going on 3rd gear and im going (slow) about to climb a hill then i just give it gass is it supposed to bogg out or get balls cause mine boggs out on 2nd 3rd etc the only gear it dosent bogg out on is on 1st my modds are fmf pipes k&nfilter boost bottle Quote
Whyzedtwofiveoh Posted February 27, 2010 Report Posted February 27, 2010 say im going on 3rd gear and im going (slow) about to climb a hill then i just give it gass is it supposed to bogg out or get balls cause mine boggs out on 2nd 3rd etc the only gear it dosent bogg out on is on 1st my modds are fmf pipes k&nfilter boost bottle Well if your RPMs are low and you are in 3rd gear going slow yes your going to bog, You either need to down shift or work the clutch to get your revs up. Quote
TwistedSheeRida Posted February 27, 2010 Report Posted February 27, 2010 No its not supposed to and ive seen you have a few other posts. Assuming your carbs are clean and your jetting is right, do a compression test it sounds like you lost your top end. My blaster would do the same thing when my oil pump went first gear was fine after that was bog fest. Quote
