midlifecrisis Posted February 24, 2010 Report Posted February 24, 2010 So the clutch lever on the shee is really hard to pull in. I have just got the bike and it hasnt been ridden much over the past 2 months, and the clutch does work correctly when put into gear. Will a cable luber work, or is it a waste? Quote
00sheerzr Posted February 24, 2010 Report Posted February 24, 2010 So the clutch lever on the shee is really hard to pull in. I have just got the bike and it hasnt been ridden much over the past 2 months, and the clutch does work correctly when put into gear. Will a cable luber work, or is it a waste? hell ya they work grab one and a good bottle of cable lube and lube it up night and day difference and i would recomend to anyone if you have a spare 20 bucks just pick up a spare cable just to have on you next order of parts. Im glad i did Quote
MILO Posted February 24, 2010 Report Posted February 24, 2010 that would be my first guess. if nothing else get some wd40 into the cable and work it till it drips out the other end. it should loosen up. if not try a new cable before anything else if the clutch seems to work ok otherwise. Quote
