It is from the heat. It could be your running a little lean, or it could be the quality of metal/chrome. Most of the time it is from running lean. What mods are run running and whats your jetting?
i just got the bike last week . its just got pro circuit platinum pipes with 304 silencers and theres no air box and im not sure on the jetting. dont wanna drive it till i get it all figured out dont feel like blowing it up .
Where are you riding, what's the elevation and temp there?? Pull the carbs and list the jets. We can get you very close to what your going to need to run.
im in ontario and its -8c not to sure about the elevation lol havent drove it in the winter just wanna get it ready for summer . the guy i got it from said it was jetted for the pipes but ill pull the carbs and list the jets.
Ok you should be right around sea level. So we will be able to get you close, you will be a little on the rich side more than likely, and you will just have to lean it out for your temp.
I am assuming your runing stock carbs?
yeah im running stock carbs . im not gunna drive in the winter just in the summer .
You should need around a 310 Main, 27.5 pilot, stock needle middle clip, 2.5 turns on the air screw. Get your self a Sync Tool and make sure your cabrs are synced. Inspect the rubber boots on the intakes and look for any dry cracked areas that might indicate a possible air leak.
That's how the stock carbs run good. Every stock setup I have seen run near sea level runs best with the 27.5 pilot. When I had stock carbs on my bike, I attempted to change my pilot out and it wouldn't hardly run. Went back to 27.5 2.5 turns and it was perfect.
I would absolutely agree w/the 27.5, but once you open them up to 2.5 turns, you could have closed them down to 1 turn out w/25 and be about the same spot. But hey, there is more than one way to skin a cat, if it works for you, rock and roll!
