T-daddy Posted February 13, 2010 Report Posted February 13, 2010 ok well just went out and sarted up the shee everything seems fine but took a little longer to start like 5 kicks with the choke all the way out the temp is about 38 outside and havent started it in months..the jets i have in is main :280 pilot:25 needle in the middle ....mods fmf pipes and prodesign filter lid off. ?... is my jetting ok to ride in the colder weather or should i bump my pilots up too 27.5 for easy starting Quote
locogato11283 Posted February 14, 2010 Report Posted February 14, 2010 you absolutely need to raise your pilot to a 27.5. most setups with aftermarket pipes and intakes require that even in the summer months. i would also raise your main to a 300 to be safe. Quote
T-daddy Posted February 14, 2010 Author Report Posted February 14, 2010 you absolutely need to raise your pilot to a 27.5. most setups with aftermarket pipes and intakes require that even in the summer months. i would also raise your main to a 300 to be safe. ok ... already got the pilots on there way ill post back in a few days wen they arrive and i install them to tell u how it runs thanks loco Quote
sleeper06 Posted February 18, 2010 Report Posted February 18, 2010 I ran 290,30 in the winter and 280,30 in the summer,stock needle richest position,I found fmfs like big pilots where we are Quote
