randomguy Posted February 11, 2010 Report Posted February 11, 2010 hey, i'm new too bansheehq. but i was hoping you guys could give some help. i have an 01 banshee. full t5 pipes, white bros boost bottle, tors elimination kit, and i'm really not sure what else, but not alot of mods. i've only had it about a week and it needs a little carb adjusting..was going to do that today when i got the banshee out. but i let it warm up and took off on it, only rode it up the road and turned..came back down and i heard a funny noise so i stopped and just turned it off. i checked it out and decided to start it back and it sounded fine holding the clutch in but once i let the clutch out, it made a whining noise and hardly no pull.. i put the banshee in neutral and pushed it back over too my house and it also made the whining noise while pushing it in neutral.. kinda like a sport utility atv when you have it in gear turned off and push it forward, they will make a noise. but it sounds like that, i could make a video and let people check it out later if needed. and also when i started it in neutral, it seemed like it wanted to try pull a little.. so the whole being in neutral pushing it and stuff is why i was currious about it. other than that i think it just needs clutches.. any opinions? thanks Quote
9banshee6 Posted February 12, 2010 Report Posted February 12, 2010 hey, i'm new too bansheehq. but i was hoping you guys could give some help. i have an 01 banshee. full t5 pipes, white bros boost bottle, tors elimination kit, and i'm really not sure what else, but not alot of mods. i've only had it about a week and it needs a little carb adjusting..was going to do that today when i got the banshee out. but i let it warm up and took off on it, only rode it up the road and turned..came back down and i heard a funny noise so i stopped and just turned it off. i checked it out and decided to start it back and it sounded fine holding the clutch in but once i let the clutch out, it made a whining noise and hardly no pull.. i put the banshee in neutral and pushed it back over too my house and it also made the whining noise while pushing it in neutral.. kinda like a sport utility atv when you have it in gear turned off and push it forward, they will make a noise. but it sounds like that, i could make a video and let people check it out later if needed. and also when i started it in neutral, it seemed like it wanted to try pull a little.. so the whole being in neutral pushing it and stuff is why i was currious about it. other than that i think it just needs clutches.. any opinions? thanks thats what happened to me later i found out mymy carb slides were messed up but when i and adjusted my carbs it ran like cherry but make the vid about it Quote
randomguy Posted February 12, 2010 Author Report Posted February 12, 2010 thanks, hopefully thats all thats wrong with mine.. but i'm expecting some bad looking cluthes. im going to check everything out tomorrow hopefully, and i'll see if it's still making the noise and take a video. float is stuck on right side carb also (guessing thats it) gas was pouring from the overflow. but i think it's more than carbs, when clutch is pulled it..i can rev it up and it sounds good and runs perfect. i think i really just need to go through the quad and and do some maintenence too it. i'll post back tomorrow after i check it out..thanks Quote
robs400 Posted March 1, 2010 Report Posted March 1, 2010 Hello - New here, went looking on the net this past weekend trying to see if anyone was having a similar issue I am having with my banshee, and I was directed to this site. Did you figure out what was wrong with yours? Aside from making the noise being pushed in neutral (I didnt try that) The issue sounds very similar to what mine is doing. I stopped mine almost instantly after it started making the noise. Checked the fluid, it was pretty low, so I added some fluid to see if it would go away, and it didnt within a minute or two so I parked it and got to tearing it apart this past weekend. A friend of mine helped pull the clutch cover off and we pulled the clutch apart...everything looked okay in there. No metal I could see in the oil I drained, altho it did look like there was a little water in it. Any info would be appreciated. Thank you! Quote
