g_low0885 Posted February 10, 2010 Report Share Posted February 10, 2010 i am going thru reat brake pads after about 10 hrs of riding. i have changed the roter thinking that it must be bent. but it is no better with the new roter. then i lifted the rear up and put in in gear the roter does not have a wobble to it. i then noticed that the caliper has a lot of play in it. is there any bushings in the caliper that could be replaced to take out the slop or do i need a different caliper all together. Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted February 11, 2010 Report Share Posted February 11, 2010 is the piston in the caliper releasing the pressure fully? if it's keeping even a small amount of pressure on the pads they wont last. can you turn the axle easily by hand with the rear end lifted? stock style or roundhouse swinger? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted February 11, 2010 Report Share Posted February 11, 2010 Sounds like something is froze up in the caliper- either the piston or the slider pins. If the slider pins are froze to the caliper it will wear pads even if the piston is free. Quote Link to comment Share on other sites More sharing options...
robert0762 Posted February 11, 2010 Report Share Posted February 11, 2010 Sounds like something is froze up in the caliper- either the piston or the slider pins. If the slider pins are froze to the caliper it will wear pads even if the piston is free. x2 I had this same problem Quote Link to comment Share on other sites More sharing options...
g_low0885 Posted February 11, 2010 Author Report Share Posted February 11, 2010 the axle turns freely. maybe it is the slider pins. can you change the slider pins? Quote Link to comment Share on other sites More sharing options...
