pitbull2424 Posted February 15, 2010 Author Report Share Posted February 15, 2010 well, keep changing the jets untill you get your wot good, and do a plug chop to confirm. THAT IS THE SIZE YOU NEED. then you play with the needle, and likely have to change it. then, you get your pilot done. i'm not real familiar with non-mikuni carb jet sizes, so someone else should chime in. Thanks!!! Quote Link to comment Share on other sites More sharing options...
