pitbull2424
    2000 Yamaha Banshee 20 over .20 shaved head, pro circuit pipes, reed spacers, K & N air filter without lid, Boyesen reeds, removed tors system, + 4 durablue axle, +2 +1 wicked aarms,and pep shocks.
Recent Profile Visitors
pitbull2424's Achievements
  1. Is this still available?
  2. 🤷‍♂️ No one else with info??
  3. So you wouldn’t put in new rings? Even if to ring gap is at .020
  4. What up guys Thanks for all the info on this site always have found what I needed. I am in need of some help that I can not find a clear answer . So I took my motor apart to put in an override. I decided to look in my cylinders for an inspection I noticed that my cylinders had Some aluminum deposit on the nickasil. so I decided to Scotch-Brite it out to see the cross hatches which are slightly their motor always ran really strong I was wondering if anybody could give me some info on what I should do. I took measurements and this is what I have on top of cylinder is 2.677 bottom is 2.677 top of piston is 2.66 bottom is 2.670 ring gap is about .020 I was thinking of putting it back Together but I don’t know if I messed up by removing the aluminum from the nickasil will my ring still seat good or should I get new rings or new pistons and rings. Any info will be appreciated thanks .
  5. Dam Iam Really looking for some 14 paddle extreme straight thanks...
  6. Are those Staggered? Where are you located?
  7. Pics on paddles??? 14ex
  8. yea I whant to say that too but fast also sells the rick stator that is known to fail so its hard to say.????
  9. hey guys whats up i have a question has any one tryed this stator http://farmandsandtoys.com/ocart2/stator-timing-plate-banshee.html?search=banshee%20statori have looked around and i know that the only stator worth buying is the oem one. but I have not found any reviews on this one. just wondering if some one has any kind of info on this one. thanks
  10. thanks iam going to give one a try.
  11. Hi, Just wondering if anobody on this site has used the alba pro elite steering stabilizer? and if anyone has a pick on how it would be installed? I'm thinking of buying one but cannot find any reviews. I know they say all the stick type stabilizers are the same, but just wondering if anyone has used this one before? And more or less what is the life line on these before a rebuilt?
  12. dek on needle 35 pilot 180 main iam at 5000 ft when i got the bike it had a 160 main ran good but it seemed to me like it was geting hot
  13. Needle size 45 that's all I could see on the slide and needle, pilot size 35, and on the float that is something I have not checked do you think it might be overflowing?
