00sheerzr Posted January 28, 2010 Report Posted January 28, 2010 these where the first things i have evr polished and they didnt come out bad considering they had tons of casting flaws and the pipes where flat black before that but were way to pitted to polish Quote
FrankieSquid Posted January 28, 2010 Report Posted January 28, 2010 Is that a steel brake lever? or aluminum? I think steel will end up rusting real quick if you get that thing wet or even the moisture in the air. Quote
00sheerzr Posted January 28, 2010 Author Report Posted January 28, 2010 Is that a steel brake lever? or aluminum? I think steel will end up rusting real quick if you get that thing wet or even the moisture in the air. it is steel but i clear coated everything so i think it should hold up ok or the worst that can happen is it rusts up and i gota paint over it Quote
VegasJeff Posted January 30, 2010 Report Posted January 30, 2010 it is steel but i clear coated everything so i think it should hold up ok or the worst that can happen is it rusts up and i gota paint over it I polished my stock steel brake pedal years ago and no rust yet. Quote
