7 mill super cub
72 mm bore with new rings pistons ok
7 mill 115 rod cranks
v force 2 reeds with 40 mm intakes
1-5 override with n down
gidgot under the cover lock up
shear big bore pipes out the left side
asking 3500 for motor pipes
You have any pic's? Also what kinda times did it run and what type of setup did you have?
ran it in a stk lightened chassis with paddles and ran 3.8's cons. and i weigh 190 lbs and here are the pics, can't get the pics to upload will email anybody interested
if motor sells with out them i want 375 thanks
Hi, have you sold the engine and carbs?.
