I was thinking the color of my shee is blue, And my chain guards are the stock ugly white can you RITT die them a color(blue) like RC rims has any one done this, Thanks Matt
im sure you can. i've died a ton of rc parts with RIT die. i dont see why you couldnt die the stock chain guides using that stuff. you will probly have to boil it in the die a little longer then you do for rc parts because of the thickness of the plastic but otherwise it should work...
sounds noob but can someone explain how this works?
[/quo
well, with RC rims you boil water add the RIT die, than shut the burner off let the water cool a little as to not melt the part and soak the part in it, make sure you tie it to a string or wire so you can keep dipping it so it wont melt. thus dies the part. un-like paint it soaks all the way threw so it wont scratch out. Rit make all types of colors you can find it at walmart for like $4.00 im going to give it a shot I'll let you guys know how it works.
  • 2 weeks later...
so did you do this yet? I would love to see how it turns out dude... im big into rc also and I have ritt dye at my house now..I have orange yellow and balck and wanna see if it turns out good on your chain guard...
no, ill be doing it next week end, i'll post before and after pic for you, I had to change the radiator and water pump in my wrangler so i have been busy
