Hello all, I'm trying to find out why my clutch is so tight or hard to pull in. I have regular clutch springs, and the cable is lub (so I think). The cable doesn't look crimp or under stress. I also have maybe 1/8 of a inch play in the lever. So what else could it be? Thanks
What kind of lever are you using? Also, you would be amazed on how much a new and properly lubed cable will improve your pull.
I'm using a standard stock lever, I might have to buy one of those cable lub tools. The cable feels fine when I dis engage if from the clutch
