Hi everybody. I have a 2004 Banshee with some mods. Here they are: port cylinder, crank mod, head planning, boysen reed, full pro circuit line, timing key, open air filter lid with k&n and boost bottle. 310 main, 27.5 pilot, br8es spark plugs. I've tried alot of kind of jetting but my spark plug always run wet. I've opened the engine and reseal it for be sure they don't have leak between the crank case and cylinder head. But it's always the same. I no it's hard to fix an engine in the net but if somebodys can give me some tips, I will appreciate.
Thanks.
French friend David
well, first things i would check is that it's getting good, blue spark with fresh plugs. next, make sure the carbs aren't overflowing into the engine, and that your air filter is not plugged. i have also hear of somthing like a rag or paper towel being sucked into a carb. and finally, do a compression test...........other than that-
NOMMM, NOMMM, NOMMM.... :yank:
akheathen is right./... but he forgot to cask you how are u checkin ur plugs.... wide open pull in 3rd. and shut off and egt ipon clutch dont let the motor rotate after its off.... pull the plug and check. plug chop it.. :headbang:
