BOOZER2009 Posted January 12, 2010 Report Posted January 12, 2010 where would be the best place to find one threaded hollow core adjuster rod that goes into the top of the carb where a throttle cable goes through? I ahve no idea how else to describe it or what its name is. one if mine is broken Quote
badassbanshee479 Posted January 12, 2010 Report Posted January 12, 2010 is this on a set of stock carbs? have the tors been removed? if so you are looking for the throttle cable adjuster on the carb top... most of the site sponsors on here should have what you are looking for in stock. Quote
BOOZER2009 Posted January 13, 2010 Author Report Posted January 13, 2010 yes stock carbs. tors are removed. thats exactly what i need. i"ll check the sponsors. thanks Quote
