iceshee Posted January 10, 2010 Report Posted January 10, 2010 i hooked up 8 LED lights on my bike installed a resitor and an inline fuse bike wont run when i turn them on, I tied them into the black and white wire that goes to the light/kill switch, any one have a fix like a wire that i should be tied into?????????? Quote
theoriginal87 Posted January 10, 2010 Report Posted January 10, 2010 i would use the green wire going to your headlight as the power source for your led lights that way they come on wen u turn on your headlights... lol but right now all u did was wire up a really expesive kill switch... but this should also help you out: http://www.dfn.com/benkaren/elecfaq.html hope this helps Quote
iceshee Posted January 11, 2010 Author Report Posted January 11, 2010 what if i want to run them with no lights on aht wire should i use then Quote
jbooker82 Posted January 11, 2010 Report Posted January 11, 2010 what if i want to run them with no lights on aht wire should i use then You should use the wires coming out of the the head light switch. When you ground the black wire with white stipe that is what kills the engine. So you have a nice kill switch. Quote
iceshee Posted January 11, 2010 Author Report Posted January 11, 2010 so i should use yellow red????????? that will give me power when i dont have the head lights on Quote
theoriginal87 Posted January 11, 2010 Report Posted January 11, 2010 so i should use yellow red????????? that will give me power when i dont have the head lights on yes the red yellow wire is what i would use for your power supply n just run an inline switch if u want to be able to turn em off. Quote
jbooker82 Posted January 11, 2010 Report Posted January 11, 2010 Or tie it in to the green or yellow wire and use the handle bar switch to turn them on and off. Quote
AKheathen Posted January 12, 2010 Report Posted January 12, 2010 there is no more/less power wires, just power. if you are using the stock switch, , you can use the headlight pigtails and you will get power to the green wires when the switch is in low position and power to the yellow wires when the switch is in high position, and use the solid black for ground. so, are you just sticking bare leds in with resistors or something? if they are led units made for 12v, then no resistors are needed. if you are just wanting to run them when it's running full time, without switches, then you just need the power and any solid black wire in the harness, or frame/engine ground Quote
